Brake problem
Brake problem
by Calibra_Mike » Mon Mar 08, 2010 6:00 pm
Just went to drive the calibra and I have no brakes, they work but you have to press dam hard to make the car stop... its like when you try and brake with the engine off... when i turn the key all the lights come on for the brake system, not hearing the abs noise you normally hear when you turn the car on... checked the ABS fuse that ok... could it be a sensor thats gone causing this or is it something worse with the servo not working?
Re: Brake problem
by k1nty » Mon Mar 08, 2010 6:09 pm
is the vacuum line intact to servo?listen with engine running for hissing around that pipe.
k1nty
Re: Brake problem
by Calibra_Mike » Mon Mar 08, 2010 6:35 pm
is that the fuel pump priming... i thought it was something to do with the abs... guess not then... lol that works fine cos the car starts...
Ill have a listen... If there was a fault with the ABS would it cause this? is this mechanical more so then electrical? I find it strange how it was working fine yesterday and now today its not... and like I said all the lights come on when you turn the key...
according to the haynes manual it sounds like its going to be a servo/vacuum problem...
Re: Brake problem
by Calibra_Mike » Mon Mar 08, 2010 7:01 pm
problem solved... the plactic adapter bit that comes out of the servo had snapped where it joins one of the vacuum pipes, bit of super glue and electrical tape and its fixed... another part to change in the not to distant future... dont suppose anyone has one of them bits laying around?
temp fix... should be ok right?
Re: Brake problem
by k1nty » Mon Mar 08, 2010 7:12 pm
Calibra_Mike wrote:problem solved... the plactic adapter bit that comes out of the servo had snapped where it joins one of the vacuum pipes, bit of super glue and electrical tape and its fixed... another part to change in the not to distant future... dont suppose anyone has one of them bits laying around?
it will probably vibrate off mate,then youll loose your assistance.as it was...hard pedal.best to put a new one one...scrappy time
k1nty
Re: Brake problem
by Calibra_Mike » Mon Mar 08, 2010 7:16 pm
great, that will be fun... there's a fair bit of tape on there and the glue did seem to set well before the tape went on, hopefully it will last for me to drive down the scrappy tomorrow...
I bet it got knocked when i was ***** about with that bloody speedeo cable...
Re: Brake problem
by k1nty » Mon Mar 08, 2010 7:18 pm
oh its good fun...every trip brings a new fault..lol.
k1nty
Re: Brake problem
by vinny_69 » Tue Mar 09, 2010 5:27 pm
thats one proper Bodge Mike :lol: almost as bad as me
vinny_69
Re: Brake problem
by Calibra_Mike » Tue Mar 09, 2010 5:46 pm
well been tot he scrap yard today and got a new plastic adapter bit, just need to go fit it now lol...
Re: Brake problem
by vec 160 » Sat Mar 13, 2010 11:20 pm
Calibra_Mike wrote:well been tot he scrap yard today and got a new plastic adapter bit, just need to go fit it now lol...
They have three calibras up at silverlake just now mike if you are looking for more bits,
Alan
Re: Brake problem
by Calibra_Mike » Sun Mar 14, 2010 1:09 am
hmmm I think a little trip to silverlake might be on the cards :)
