Hub to driveshaft torque setting on 2.0i 8v
Does anyone have the correct torque setting for the nut that holds the hub to the drive shaft on a Calibra 2.0i 8v? The manuals are a bit confusing so wondered if anyone knows.
Re: Hub to driveshaft torque setting on 2.0i 8v
tighten nut in 3 stages
1. 130 NM
2. slacken off
3. 20NM + 80 degrees then if holes dont align for split pin (if castle nut) turn to 90 degrees
1. 130 NM
2. slacken off
I'm being thick I know - but just so I understand completly... I understand doing them up to 130NM, then slackening off and then tightening up again to 20NM but what does the + 80degrees and - 90 degrees relate to? Are NM divided up into degrees or are we talking about turning the tightening bar?
it means tighten it by an angle of 80 degrees .....so imagine it was a clock
so roughly from 12 to 2 .
to be quite honest.......... just damn tight is all all I do
your also meant to use a new nut and washer
As Fraz said 'to be quite honest.......... just damn tight is all all I do' - that I understand. I was assuming but unsure the 80 degrees was as you say turning the bar another 80 degrees but was even more unsure about the -90 degrees.
How the hell did they come up with the formula - 'just damn tight' and everyone knows what they mean.
Thanks everyone for their advice.
never had a wheel fall off yet (unless Steve worked on the car lol)
