Wilwoods on Corsa B
Wilwoods on Corsa B
hello 2 questions to ask
1. do you know if calibra turbo calipers and discs 288mm fit a corsa B (redrilled to 4 stud)
2. does anybody have wilwood 4 pot calipers on their car and where did you get the caliper brackets
thanks
thanks
robo c20let
Re: Wilwoods on Corsa B
My son has 288mm discs and GSI calipers on his Cosra B which he got as a kit from LMF and I wouldn't redrill discs.
they have been done professionally by the looks of it. i was going to stick my wilwood calipers on but that would have been a bit ott lol
robo c20let
robo c20let wrote:they have been done professionally by the looks of it. i was going to stick my wilwood calipers on but that would have been a bit ott lol
why would superior braking be over the top?? if you got em, use em!!
superfox233
how can you tell if ( they look as if been done professionally ) if there no reciept dont use as if they not right it your life and everybody elses you putting at risk
solution get some 288 four stud discs you know are 4 stud
cally8valver
I had wilwood midilite 4 pots on a 4 stud, 15" rim Calibra using 280mm discs. Now fitted to my Astra.
I bought the kit including mounting brackets from Rally Design.
http://www.rallydesign.co.uk
garyb
garyb wrote:I had wilwood midilite 4 pots on a 4 stud, 15" rim Calibra using 280mm discs. Now fitted to my Astra.
i have just been looking at them last week- i guess they are quite good are they? how much you end up paying?
- Club Member
[quote="stevo turbo
i have just been looking at them last week- i guess they are quite good are they??[/quote]
Yes.
And No.
Yes, in as much they have a much better, direct feel than the poor standard 256mm discs/ single piston GM stuff they replaced. I can't remember the difference in piston area & weight between the stock GM & Wilwood Midilite calipers but it is substantial. As you would expect, the difference in stopping power was amazing. Oh and they look rather scrumptious too.....
No in as much that I think that the 308mm GM kit is better. Of course, you need 16s for this. Also when I fitted the Wilwood kit, I replaced the stock rubber brake lines for Goodridge braided stainless steel jobs - an essential upgrade for the Calibra braking system - so some of the dramatic improvement wil almost certainly be down to that.
I paid whatever the Rally Design quoted price was at the time; I don't think it was much different to their current price.
Yes.
And No.
garyb
so worth looking at for the calibra them. was thinking jus keep the standard disc size. 288 i think they are
- Club Member
