Electric Power steering pump on a calibra turbo
by nigelh » Sun Jun 13, 2010 9:10 am
Does anyone know if the electric power steering pump from a astra H would make enough pressure to run the power steering and ram clutch for the transfer box on a calibra turbo?
Thanks
nigelh
Re: Electric Power steering pump on a calibra turbo
by stevo turbo » Wed Jun 16, 2010 8:05 am
not sure is my answer but i think i have read that you are looking for about 800 psi for the transfer box to work iirc
by GreyDJ » Wed Jun 16, 2010 12:12 pm
stevo turbo wrote:not sure is my answer but i think i have read that you are looking for about 800 psi for the transfer box to work iirc
Is that the txb pressure after the accumulator? If so the pressure on the p/s fluid side would be lower.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
by bodgetastic » Wed Jun 16, 2010 1:06 pm
Dan went down the route of a locked box though due to fitting an electric pump afaik
