ABS
ABS
by scott_j_g » Thu Aug 05, 2010 2:15 pm
Hay there peeps.
wee question for you, is there a way to adjust the sensativity of the ABS?
Mine is far to sensative, i have taken out the fuse for now so have no ABS at all :(
scott_j_g
Re: ABS
by Calibra_Mike » Thu Aug 05, 2010 2:31 pm
you might have a sensor on its way out, did the ABS light ever come on while driving or braking?
Re: ABS
by scott_j_g » Thu Aug 05, 2010 2:34 pm
Calibra_Mike wrote:you might have a sensor on its way out, did the ABS light ever come on while driving or braking?
hmm calibras and there bloomin sensors, no the light never came on
scott_j_g
Re: ABS
by Tangerine » Thu Aug 05, 2010 4:18 pm
could it possibly be a tooth missing on an abs ring? usually that causes the abs to kick in more or less all the time
Tangerine
Re: ABS
by k1nty » Thu Aug 05, 2010 4:18 pm
check the white sensor plugs and the rings on hubs first.its not sensitive unless theres a lock up as with any abs system.
k1nty
Re: ABS
by scott_j_g » Thu Aug 05, 2010 5:27 pm
cool that gives me a few things to look for il prob end up just taking it to the garage unless its somthing obviouse and within my skill to fix :)
cheers guys
scott_j_g
Re: ABS
by k1nty » Thu Aug 05, 2010 5:34 pm
i would say a corroded split reluctor ring...jack each wheel up and scrape/wirebrush the crud off .
k1nty
