Bleed screws
Bleed screws
Brakes a bit spongey so bled the fronts ok, on attempting to do the rears noticed the bleed nipple things were leaking so assume thats the cause of the air intake into the system.
Question is can these bits be replaced or is it the whole calipre that needs to be replaced?
Re: Bleed screws
Bleed nipples can be replaced, but be careful as they can easily snap as well.
Re: Bleed screws
might just go for replacement calipres as they look pretty rotten around that area
Re: Bleed screws
give them a try, if it sanps then go for a caliper. you can get both from your local motor factors. also you will find they probably do a exchange item for the calipers if needed.
hint, use plent of wd40 when trying to move the old nipple
- Club Member
Re: Bleed screws
there are bleed nipples?
Re: Bleed screws
gice them a good coating a few days before Rob and they should come off just fine
vinny_69
Re: Bleed screws
Opted for the new recon calipers, as the luck i've been having with it lately sucks just waiting for delivery now
Users browsing this forum: Google [Bot] and 31 guests
