Calibra Turbo 4x4 17inch tyre pressures?
Hi
Does anyone know what is the correct Tyre presures in a Calibra Turbo 4x4 (locked using Mike Hayward locking kit) running 17inch alloys 215 40 17 tyres?
I am running 35PSI all round. Is this about right or not?
Re: Calibra Turbo 4x4 17inch tyre pressures?
Hi, but the book does not cater for 17inch alloys so bigger tyres, plus a locked 4x4, i just did not know. I was recommended with a locked box to keep same pressures all round, but not sure what pressure.
would bigger tyres make a difference being not 16's on 17's 215 40 17. So 35 sounds too much?
The tyre expert site http://www.carbibles.com/tyre_bible.html recommends using the max pressure written on the side of the tyre minus 10%.
I do that the first time I use a car/tyre combination then change the pressure to suit the tyre wear, down if the centre wears first and up if the edges wear.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
i run 35 front and 32 rear on my 17 x 45 x 215's and have done since the tyres were new 11 months back and no sign of any wear yet
