ebay suspention
ebay suspention
by stevo turbo » Thu Mar 17, 2011 9:16 am
http://cgi.ebay.co.uk/Eibach-springs-Va ... 19c3e1fe33
someone posted this link a couple of days ago but not sure if many people have seen it, i know the guy says its fitted to a dtm but i know its not right but i would like to know if they should fit a dtm turbo without too much difference or cause any problems with them being 25mm drop as standard?
Re: ebay suspention
by v6 steve » Thu Mar 17, 2011 9:53 am
if they came off a turbo then they should be fine the DTM's came with 25mm lowerd springs as std he probaly is thinking 25mm drop from std hight of std car not an extra 25mm from dtm's
Re: ebay suspention
by GreyDJ » Thu Mar 17, 2011 11:44 am
Did the DTMs come with the same 'lowered by 30mm spring but raised by a 5mm pad' setup as a LE, giving a net 25mm drop?
If so, these could be a 30mm drop from standard if the pads are missing.
Cavalier CDi 96 Grey
Cavalier SRi 93 Satin Red
Cavalier Mk2 CD130 86 White
Re: ebay suspention
by v6 steve » Thu Mar 17, 2011 8:49 pm
GreyDJ wrote:Did the DTMs come with the same 'lowered by 30mm spring but raised by a 5mm pad' setup as a LE, giving a net 25mm drop?
What pad are you talking about?
Re: ebay suspention
by GreyDJ » Thu Mar 17, 2011 9:44 pm
An about 4" round flat 'rubber' disc that sits under the bottom normal 'rubber' disc with a bump in that's at each end of the spring.
Re: ebay suspention
by v6 steve » Thu Mar 17, 2011 10:11 pm
all calibras have them not just LE's or DTM's so they have nothing to do with adding 5mm on the ride hight, i think there so the spring dosnt rattel and ware its self away
Re: ebay suspention
by GreyDJ » Fri Mar 18, 2011 2:59 am
That surprises me.
I know that on all rear beam Cavaliers there is one rubber 'washer' at each end of the spring to help hold it in place and to keep it away from the top/bottom spring seats. The same are also on the Calibra.
I have just not seen this extra 'washer' before my LE and don't understand why it is there as there is no apparent mechanical reason for it.
If it is on the Calibra then is it on IRS Cavaliers as well?
Re: ebay suspention
by garyb » Wed Apr 06, 2011 8:44 am
v6 steve wrote:all calibras have them not just LE's or DTM's
The description was slightly wrong, the LE has an extra 5mm hard rubber disc. Also the LE is on 25mm drop springs, this 5mm disc makes the rear 20mm.
I used them on my Turbos in combination with Eibach Pro springs before swapping to coilovers.
( I'm almost certain that Eibach also made the Irmscher branded springs used on the LE, I can check pretty easily if someone wants absolute confirmation. )
garyb
Re: ebay suspension
by v6 steve » Wed Apr 06, 2011 9:05 pm
garyb wrote:
v6 steve wrote:all calibers have them not just LEts or DTM's
does anyone have a pic of these 5mm padds iv just looked at the DTM in the garage and its no different to my v6 or turbo
Re: ebay suspention
by GreyDJ » Wed Apr 06, 2011 11:37 pm
Not sure how to post them but PM me your email address and I'll send you a picture in the morning.
Re: ebay suspension
by garyb » Thu Apr 07, 2011 4:22 am
No acces to pix from current location but if it helps the part number is i2704002, maybe 92704002 on Vaux EPC systems. I bought mine through Autovaux but that was sometime ago, they're probably NLS now.
garyb
