Rear Brake pads
Rear Brake pads
by Calibra_Mike » Sun Jun 26, 2011 11:55 am
Im pretty sure these will fit but can someone back that up?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
anyone also know where I can get a fitting kit from? the pins and sliders etc...
Re: Rear Brake pads
by big_gordy » Sun Jun 26, 2011 12:49 pm
i know halfrauds used to do them but any local motor factor should have em
Re: Rear Brake pads
by Fraz » Sun Jun 26, 2011 4:08 pm
they will fit, but why bother with them expensive ones, there are cheaper ones out there
Re: Rear Brake pads
by Calibra_Mike » Mon Jun 27, 2011 7:36 am
Same as what I have on the front and they've lasted ages and work goos enough...
Ill check out my local motor factors for the kit...
Re: Rear Brake pads
by Rocket » Mon Jun 27, 2011 9:11 am
The rear's do very little work had the same set on mine for 5 years
Rocket
Re: Rear Brake pads
by Fraz » Mon Jun 27, 2011 1:15 pm
you the rear brakes are there simply to stop the car spinning while braking, think its about 15% of the braking efficiency is to the rear, so any pad will do really ...the front is the place to spend the money
Re: Rear Brake pads
by Calibra_Mike » Mon Jun 27, 2011 7:19 pm
Ive got a set of pads and the fitting kit on order form my local motor factors for about £15 plus vat, picking up tomorrow... will use the savings towards other bits im after...
