Calibra steering rack removal question?
by LE16 » Thu Oct 06, 2011 6:09 pm
Does anyone know a good way to get the bolt out from between the servo and rack? I have managed to get a 3/8 13ml between but it doesnt seem to catch the bolt so I cant even tell if the socket it right. All the other bolts are off and they are 13ml. Any one done this before? I cant get the servo off as there is no space to manouver and the bolts for it are behind the servo and not behind the bulkhead/footwell making it 10x harder.
I only have two bolts left and its annoying me now :bazooka:
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
Re: Calibra steering rack removal question?
by v6 steve » Thu Oct 06, 2011 6:29 pm
i put a pinch bar under the master cylinder and the top of the wing and pushed down a littel giveing me enough room to get it out
by LE16 » Thu Oct 06, 2011 6:35 pm
I'll try that. Just found my manual which says to take out the wiper and there are two mount bolts behind the bulkhead. I'll see if I can lever it first as you say then if that is too cramped I'll go for plan B thanks mate.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
by bodgetastic » Thu Oct 06, 2011 7:01 pm
se5 wrote:Just found my manual which says to take out the wiper and there are two mount bolts behind the bulkhead.
Thats what I do
