Powerflex front bush issue?
Hi,
Was able to fit the lower (rear) no problem but the front wishbone bush is hard to get into the subframe (with powerflex) to the point where I cannot align the bolt hole. I measured the front bush at 65ml and the OEM as 60. Unless I am doing something wrong here? Just wanted to know if anyone else had this problem. Have checked they are the correct bushes and Powerflex think that the wishbone may be larger. But if that was the case then it's likely I would see the original as being 65 and they are not. So wondering if anyone else noticed this and what they did to resolve it?
Sean
Sean
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
Re: Powerflex front bush issue?
Also,
Has anyone got an original GM wishbone that is worn or minus the front bush? PF want me to measure the ID as they think the Trupart may be a deviation.
Cheers.
Cheers.
Sean
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
SE5 Turbo
LE 07
LE 16
LE41
Turbo
Another Turbo
Se7
V6
16V
16V XEV
8v
- Gold Member
