Brake Lines
Brake Lines
by Phantom » Fri Apr 06, 2012 1:47 pm
just a quick note if you're ever replacing the HL line from the ABS unit you will find the fitting is a bigger thread than all the others :roll:
Re: Brake Lines
by v6 steve » Fri Apr 06, 2012 4:45 pm
i had that problam when i put the turbo in the se2 luckily the old was in good condition so i re used the original end :D
