been very very busy!
by craigyboy » Fri Apr 20, 2012 10:31 pm
lower arms and subframe stripped!
poly bushes fitted and painted
all ready for re-fitting
all fitted
fit the wheels tomorrow bevy time :obscene-drinkingbeer: :D
Re: been very very busy!
by v6 steve » Fri Apr 20, 2012 11:15 pm
:clap:
by big_gordy » Fri Apr 20, 2012 11:32 pm
:clap:
by stevo turbo » Fri Apr 20, 2012 11:59 pm
good work but why does it look like you have painted the discs also?
by Mark1 » Sat Apr 21, 2012 7:24 am
Came up nice.
by craigyboy » Sat Apr 21, 2012 8:58 am
stevo turbo wrote:good work but why does it look like you have painted the discs also?
Just the centre parts Stevo,painted them with high temp paint
the rest is over spray which i'll rub off today.It is just to cover
up the surface rust
by Allys Cally » Sat Apr 21, 2012 9:01 am
that crossed my mind as well :think:
by Fraz » Sat Apr 21, 2012 12:21 pm
very nice Craig...lots of work going on
oh I made the mistake of painting the vents on the disc....even with high temp paint your going to find the inside of your wheels covered in wee spots of paint once you use them ..combination of heat and centrifugal force means the paint will get flung off through the disc vent holes
by craigyboy » Sat Apr 21, 2012 7:00 pm
Thats it finished now,sounds alot better with the poly bushes
and new shocks fitted,it feels a more firm drive.No more clunking
sounds :dance:
by Callyman » Sat Apr 21, 2012 7:09 pm
Great work there Craig. :clap:
by EddeyDancer » Mon Apr 23, 2012 10:40 am
Good Work Mate...
I'm not so sure about the Colour RED on any Calibra, but I hope it's giving You a better ride... :clap:
by craigyboy » Mon Apr 23, 2012 5:02 pm
Cheers for the comments guys,i think it definetly
freshens it up a bit :handgestures-thumbup:
by EddeyDancer » Mon Apr 23, 2012 7:34 pm
At least the Corrosion situation, is being dealt with!!!
It's always good to know, what the condition of the Car is in...
Helps put your mind at ease!!! :think:
by James_Mould » Mon Apr 23, 2012 8:24 pm
Good work there mate. Looks much better 8)
by craigyboy » Sat Dec 22, 2012 9:38 pm
Front end all stripped again.putting back on lower arms
with ordinary rubber bushes,fitting new bilstein shocks
and apex springs.heres hopping the rides alot smoother
planning to post some pics tomorrow
