I've got the judders!
I've got a 94 v6 and at the moment when i brake from speed, say 60 and above i get a judder on the steering wheel and it feels like shes pulling to the right. I know thw brake pads aren't worn out as they were new on in february. I've got no warning lights come on and when i come to a stop it will pull hard to the right. Any ideas?
fatboy_v6
It's your disks - check the lip on them - you'll find quite a large difference between the thickness right at the edge and where the pads start to bite.
They've got warped due to overheating as they are too thin now... mine did the same and I got the whole lot replaced... it's best to get the pads done at the same time as the disks as you'll only score the new ones as soon as you use the old pads....
Kieran_Burns
Another little win on ebay :-)
They'll probably hold out for a while as long as you don't do too much track racing, make sure you take it easy [img]/wink.gif[/img]
skellem
Well i don't usually use em that hard unless i have to. Shes gotta have a few other bits done as well. I know shes leaking oil but not a lot and i'm not sure where from but the underneaths gonna be steamcleaned and re undersealed so i'll get the engine done too and see if that sheds any light on it.
fatboy_v6
