Squealing Brakes
Squealing Brakes
My new Calibra is suffering from quite bad brake squealing under light braking. If I brake hard it does not happen. The pads are not worn and the discs are not corroded or scored. Any ideas what might be causing the problem.
Regards
Pinner-man
Regards
Pinner-man
- Gold Member
Re: Squealing Brakes
I'd suggest copper grease on back of pads and on the parts of the pad that slide on the caliper.
Also ensure you have an angled edge on the leading edge of the pad.
That should help.
That should help.
Thanks for the suggestion. I will check in the next day or two.
- Gold Member
Agreed, I've always done it, and every mechanic I know still does.
