Bigger brakes
Bigger brakes
by calidaz » Wed Jan 27, 2016 9:46 pm
Howdy all just a quick question I would like to fit bigger brakes to my xev calibra any advice on a decent setup without spending big money?
Sent from my HTC Desire 510 using Tapatalk
Re: Bigger brakes
by Allys Cally » Wed Jan 27, 2016 9:59 pm
You could go for v6/turbo brakes which will take you up to 288mm discs. You can buy the 288mm drilled for 4 stud hubs. But the minimum size alloy you can use is 16in with these.
Re: Bigger brakes
by calidaz » Wed Jan 27, 2016 10:23 pm
Thanks for reply so all I really need is the v6/turbo callipers and do they go straight onto the dev setup I have17s on the car and the breaks look tiny lol
Re: Bigger brakes
by BigDaz » Wed Jan 27, 2016 10:28 pm
Allys Cally wrote:You could go for v6/turbo brakes which will take you up to 288mm discs. You can buy the 288mm drilled for 4 stud hubs. But the minimum size alloy you can use is 16in with these.
Same setup i have on mine and you can go as little as 15in wheels but it is tight as i have 15in cavalier slabs on mine but there is only about 3mm clearance
'Once Driven Forever Smitten'
Re: Bigger brakes
by Allys Cally » Wed Jan 27, 2016 10:35 pm
Wasn't 100% sure if the 15in fitted with the 288mm reason why I played it safe and said 16in :lol:
Re: Bigger brakes
by BigDaz » Wed Jan 27, 2016 11:48 pm
calidaz wrote:Thanks for reply so all I really need is the v6/turbo callipers and do they go straight onto the dev setup I have17s on the car and the breaks look tiny lol
They bolt straight on no problems any v6 calibra,cavalier or vectra will fit you will have to change low brake pad wiring tho but the cables are cheap
Sent from my SM-G925F using Tapatalk
Re: Bigger brakes
by rips » Thu Jan 28, 2016 12:21 pm
With that little clearance, you may find that the variations in design of the wheel will take up this space.
A friend of mine upgraded his Lotus M100 Elan with Vectra V6 calipers (M100 Elans have mainly GM components & the original front calipers are slightly modified Astra GSi ones). He had Vauxhall 15" alloys on his & when he first drove it with the bigger brakes, he heard a 'tick-tick-tick' sound as the balance weights got knocked off.
1990 Elan SE Pacific Blue
Re: Bigger brakes
by BigDaz » Thu Jan 28, 2016 2:06 pm
[/quote]
He had Vauxhall 15" alloys on his & when he first drove it with the bigger brakes, he heard a 'tick-tick-tick' sound as the balance weights got knocked off.[/quote]
This can be a problem with some wheels i had to shave the weights down and use more but as calidaz is using 17inch there will be no problems
Re: Bigger brakes
by calidaz » Fri Jan 29, 2016 12:16 am
Thanks for replies guys,I was talking to a mate to day he has the full v6 5stud hubs and brake setup so might go down that road and do the whole change over
Re: Bigger brakes
by BigDaz » Fri Jan 29, 2016 12:27 am
calidaz wrote:Thanks for replies guys,I was talking to a mate to day he has the full v6 5stud hubs and brake setup so might go down that road and do the whole change over
That will be my next move as well loads of better wheels come in 5 stud :x8-)
Re: Bigger brakes
by calidaz » Fri Jan 29, 2016 12:29 am
Definitely a nice set of bbs,Rota or xxr 18s
Re: Bigger brakes
by calidaz » Fri Jan 29, 2016 12:34 am
Re: Bigger brakes
by BigDaz » Fri Jan 29, 2016 12:37 am
Always wanted a set of cavalier/calibra turbo fan blades but can never find any for sale. But slammed on rotas that would work
Re: Bigger brakes
by Callyman » Fri Jan 29, 2016 11:20 am
BigDaz wrote:Always wanted a set of cavalier/calibra turbo fan blades but can never find any for sale. But slammed on rotas that would work
https://www.facebook.com/photo.php?fbid ... =3&theater
Re: Bigger brakes
by BigDaz » Fri Jan 29, 2016 9:11 pm
Link doesn't work a Andy as am not on face ache
