std springs
by gran » Sat Feb 14, 2004 11:24 am
anybody know if i can get hold of standard height front 16v springs that are harder than vx ones? im doing a little experiment!
im on the 3rd set of custom springs for the front but they've all been too soft.
will V6 fronts fit? they must be harder due to the extra engine weight right?
...........wheres that angle grinder!
gran
by Topbuzz » Fri Feb 20, 2004 5:50 pm
For inofo all Calibra shock absorbers will fit all modesl of Calibra, ie turbo shocks will fit 8v Calibra, they use all the same mounting points. So in theory you can fit the springs from any Calibra too.
Alan Knight (Topbuzz)
W: www.topbuzz.co.uk
E: webmaster@topbuzz.co.uk
by Dan Willis » Fri Feb 20, 2004 5:59 pm
Thats interesting... I still have stock turbo springs... and an 8V! I wonder...
Dan
by gran » Fri Feb 20, 2004 7:34 pm
are you thinking opposite 2me dan? :twisted:
gran
by jaybv6 » Fri Feb 20, 2004 7:53 pm
V6 springs will be harder but will make the fron of your 16v look like it's on stilts. One you start angle grinding coils off you start to make the spring weaker.
jaybv6
by Dan Willis » Sun Feb 22, 2004 6:54 pm
Sort of Gran... When I replaced my Turbo suspension with Koni's I kept the springs (shocks were shot). I might chuck em on my new 8v.
Cutting springs is really really bad.
Dan
by Cally-boy » Sun Feb 22, 2004 6:56 pm
Gran how about a set of say -35mm springs for a V6 fitted may only give you about -25mm on a 16V due to less weight
May be worth trying to find out the spring rates and working out how much it'll drop by compared to the difference's in axles weights
Cally-boy
by CHARLIE » Sun Feb 22, 2004 7:06 pm
im just about to take my standard springs out of my 16v + am putting some new ones in. so if you want some original springs let me know, they are all yours if you want them [img]/biggrin.gif[/img]
CHARLIE
by gran » Sun Feb 22, 2004 8:10 pm
cheers for that offer but ive got a couple of sets of 16v springs.
some std v6 springs would be nice though........................... :?:
gran
