Clicking noises again!!!
When i pull away or sometimes change speed (ie. change gear), and sometimes whilst braking, i get a clicking noise. It kinda just clicks a couple of times and thats it until i change speed etc again. it is coming from the drivers side front wheeel area.
I have just replaced the wishbone(and ball joint), ARB link, so its not these. I have taken the CV joint off to have a look but it all looks fine to me. I have also got the suspension strut off at the moment so i am checking that. Nothing appeared to be loose when i took it all off!
Before i put it all back together again and double check its all tight, is there anything ive missed??
Any help again would be appreciated! I dont know what else it could be.
Dawson16v
Is your strut top bush and bearing ok?
Look for the centre metal section on the mushroom shaped bit, Should be flat and not carcked or domed(concaved)
Condition of the trackrod end ball joint, or the arm it's self where it's connected to the rack?
Longshot but are your engine mounts fine?
Another longshot , Is your spring sat correctly in it's seat both top and bottom?
Mac
