Camber kit
by DJNIK » Mon Dec 20, 2004 3:25 pm
i've got Eibach springs today 25mm lowering. Question is do i need camber kit??? Some ppl say i dont need it some say i need. I need help as soon as posible
cheers
DJNIK
RE: sunroof knackered... help please
by 4x4Turbo » Mon Dec 20, 2004 6:04 pm
your best way is to fit the springs etc and then see what the camber looks like it also depends what size wheels youve got mines got 17's with a 35mm drop and the camber is ok however when you have a couple of people in the back there is alot of camber so i could probly do witha camber kit myself its one of them things im just not sure what to do really myself, see how it looks mate! [img]/smile.gif[/img]
4x4Turbo
by Novaneil » Thu Dec 23, 2004 8:53 pm
Where can you buy the camber kits? And is it for the rear and front? As mine looks like the rear has massive negative Camber, but the fronts aren't too bad.
Neil
Novaneil
RE: Re: RE: My V6 Roar (vid)
by 4x4Turbo » Thu Dec 30, 2004 11:44 am
you can buy them from regal autosport or courtney turbo places like that sell them and yes you can get them for the front and back
hope it helps
olly
4x4Turbo
by martynlewins » Mon Jan 03, 2005 11:15 am
My 8v was dropped 60 and the camber was that far off the inside of my tyre wore like youd never believe. The 16v was dropped 40 and the camber on that wasnt too bad.. Still noticable like but not half as bad on the tyres..
IMO if you want to save money on tyres and do it properly then id get the camber correction done. It will give you better traction too as all your tyre will be in contact with the road as apposed to maybe just 80% of it.
I always thought tho, it was a definate no no lowering a turbo without Camber correction as it puts a lot of strain on the TX box?
Martyn
martynlewins
RE: Xado - What you think?
by Vid » Mon Jan 03, 2005 11:38 am
I was under the impression you could only get the camber correcters for the rear, never heard of adjusters for the front? Anyone else?
Vid
by Novaneil » Tue Jan 04, 2005 1:33 pm
Does anyone know the price of the rear correction bushes?
Neil
Novaneil
RE: Oil / Volt gauge - wire colours on loom
by Phil69 » Thu Jan 06, 2005 1:09 pm
Vid - your not the only one. I too thought they were only available for the rear as the fronts travel up and down not curving in as the rears do!
Maybe I'm wrong though?
RE: Goosed alarm
by SukySaggi » Thu Jan 06, 2005 4:25 pm
Yeah. camber correction bushes are only for the rear.
SukySaggi
by FatLadZ » Thu Jan 06, 2005 5:11 pm
try autovaux and also try australian ebay
theres a guy on there does offset nylon rear bushes
fatz
FatLadZ
by 4x4Turbo » Thu Jan 06, 2005 6:08 pm
i must be wrong but im sure i seen them for the front somewhere or maybe i read it wrong, sorry guys!!
olly
4x4Turbo
RE: Internet explorer problem HELP!
by 4x4Turbo » Thu Jan 06, 2005 6:14 pm
ive just found it! as in novaneil other post in regals advert for the camber correction bushs it says the fronts bolt on etc this is what has confused me too!!!
4x4Turbo
RE: Goosed alarm
by FatLadZ » Thu Jan 06, 2005 7:37 pm
i like the look of the Noltec kit
<a href="http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4514604742" target="_blank">http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...item=4514604742</a>
<a href="http://www.noltecsuspension.com/gmh.htm" target="_blank">http://www.noltecsuspension.com/gmh.htm</a>
FatLadZ
by Vid » Tue Jan 11, 2005 1:06 am
I had not seen this kit before, wonder if anyone on here has used them??
It's definately a cheaper option than Regal or Cav16!!
Vid
by FatLadZ » Tue Jan 11, 2005 1:09 am
not heard anyone on here with this kit
but its certainly an option at that price mate
fatz
FatLadZ
