HELP - Vaux don't know what my rear brake pads are!!!!
I've bought new pads from Vauxhall and tried to fit them but the holes that the pins go through are too close together. I took them back but they say they are the only pads listed and can't help me!!! Below is a pic of my pads, can anyone tell me if they have had this problem too? Anyone have access to the vauxhall parts system and can tell me what these are?
Thanks, Rich
Thanks, Rich
RichM
cmon test your reactions with the BBC
on epc though mines is an old one ..C25XE 90297537 and also C25XE and X25XE 90421528 its says range for the first set as
-S1
-S9
second set range as
T1 -
T9 -
not sure what that means but could be chassie number or engine number range as in T1111964 or what ever ?
-S1
-S9
second set range as
T1 -
T9 -
RE: limewire
Rich....
I had EXACTLY this same problem with them last year... went to fit the new pads and found the same thing as yourself [img]/smile.gif[/img]
The solution... get Vectra V6 rear pads... job done. They're a perfect match.
Smurf
