Brake fluid change
Brake fluid change
Its time i changed the fluid so shes safe on the road,
Whats the best fluid to use in a calibra turbo?
And what order do i bleed them in?
Rusty_CallyT
I've always understood it's necessary to bleed the fronts first on an ABS-equipped car - at least that's what I do! Not sure if it matters which order you do the left or right side though, I have just assumed not and my car still stops (ish) [img]/wink.gif[/img]
I use DOT4 fluid, largely because I have a big tub of the stuff lying around. I think it has a lower boiling temp than DOT5 (bad) but lasts longer before taking on too much moisture (good).
All of the above could be ********. It's just what I believe to be the case!
BenW
It usually matters which wheel u do first, on the ABS system the two braking circuits are front and rear.
I would do the drivers side first then pasenger as the drivers side is furthest away.
DOT 4 is what is recodmanded by vauxhall. To make life easier there are a number of bleeding kits avalable to make the job alot easier.
Dicky
Dicky
dicky
<!--QuoteBegin-dicky+--><div class='quotetop'>(dicky)</div><div class='quotemain'><!--QuoteEBegin-->Yeah, DOT4.
Also be carefull when loosening and re-tightnening off those caliper bleed screws as they are very easy to sheer off.<!--QuoteEnd--></div><!--QuoteEEnd-->
yes i have heard all about that and it worries the hell out of me, any tips? gallons of penetrating oil? i have an air powered impact wrench lol might be a bit OTT for the job tho
Rusty_CallyT
Oil wont do much but when u put the spanner on the bleed nipple giv the spanner a tap with a hammer just to loosen it a bit.
Just be very carefull when re-tightning them, dont go over the top.
U know that u have to bleed the systmem until there are no bubbles at all in the bleed hose and make sure u dont let the brake fluid tank go bellow the MIN line when bleeding the brakes.
Good luck
Dicky
Good luck
Dicky
dicky
