would these seats fit in a calibra
Re: would these seats fit in a calibra
im sure the vectra base is a 3 seater,unlike the calibra which is a 2 seater so should be shorter?
i know the backs look smaller so doubt it would be easy,maybe if you handed your seats and the vectras to a trimmer it could be done,probably have to remould the foam backings to siut aswell.
specks
v6 steve wrote:yee your right what your saying but Big Gordy will just want to stick them straight in to his car
yip steve you know me to well but i might go and do it! as i like the back seats on the gsi as it has the arm rest in the back!
v6 steve wrote:cally8valver wrote:if bottom of vectra seats are flatish like the cali then a local fabricator should be able to make some sub frames out of yours to go onto the vectra bottoms??????
the cally ones arent flat they are shaped and im sure te vectra ones will be bigger so the wont fit in the space
My mte josh has calibra seats in an old mini. Fit fine. He just got some special subframes that had a wee bit of welding done using a calibra frame, and bam, job done, they look the mutts nutts too!!
just for the record Big Gordy asked if these seats would fit a calibra the answer to that is no not with out modifying them,i I think iv already proved things can be done if you put your mind to it or have the money to pay someone to do it,
v6 steve wrote:just for the record Big Gordy asked if these seats would fit a calibra the answer to that is no not with out modifying them,i I think iv already proved things can be done if you put your mind to it or have the money to pay someone to do it,
Sorry
