rot spreading at arches, whats best rust sealer ?
Not used cally in a year, took it mot..fail on rust underbody. sorted that, rebuilt the front cross member, underseal etc ... but the wheel arch job has failed after just 5 months, rust back.
Anybody had to deal with this ?
I ground down to bare metal. applied hammerite Kurust which is supposed to be good. Sealed with epoxy, then top layer of P40, paint spray from can.
Was light on the laquer as didnt want a panel mismatch. think thats the problem. i.e. the laquer is what keeps out the water...or is there a better rest holder than Kurust ?
Re: rot spreading at arches, whats best rust sealer ?
the only way to get rid of rust 100% is to cut out and weld in new metal
v6 steve wrote:the only way to get rid of rust 100% is to cut out and weld in new metal
Cant go that far just now. seasonal fix only
Anybody tried these Yank bodyshop products or the like ?
POR-15
http://www.por15.com/
SKYCO OSPHO
http://www.ospho.com/
6950( ) - RUST-MORT
http://www.semproducts.com/Catalog.asp?prod=164
