After Market Gear Knob
by gazcallyt » Sun Jan 01, 2012 8:26 pm
Guys got a new knob for xmas oh err, I removed the old one, but underneath is a plastic bit, didn't want to remove this as it looks like the reverse lever tension spring needs it, is that right or when removed is the spring kept in place by something else ?
Gaz
LET the fun begin.
Re: After Market Gear Knob
by gazcallyt » Thu Jan 05, 2012 9:21 pm
I'm guessing the plastic thing left behind will pull off and the new knob can then be fitted to the shaft and the reverse spring will use the bottom of the new knob for tension ?? will going to give that ago at the weekend.
Gaz
LET the fun begin.
by v6 steve » Thu Jan 05, 2012 9:43 pm
it will depend on what gear knob you have got the one on mine still has the plastic lift
by craigyboy » Thu Jan 05, 2012 11:24 pm
You have to get the proper one that Richbrook make
it has the wider gap at the bottom so the reverse lift
can come up
by gazcallyt » Fri Jan 06, 2012 2:23 pm
Cheers lads.
LET the fun begin.
by Mark1 » Fri Jan 06, 2012 5:08 pm
I can't change my knob :(
by Callyman » Fri Jan 06, 2012 7:34 pm
Mark1 wrote:I can't change my knob :(
Has it shrivelled up Mark?
by Mark1 » Sat Jan 07, 2012 8:38 am
I don't think so, it's black plastic!
