digi dash?!?!?
I had one in my Cavalier it looked sweet.
The 8v dashes had a half moon rev counter, where as the 16v had the torque curve as the rev counter.
You will also need the transducer that came with the clocks as there are about 80 different varieties which go by VIN number.
I think it will look good if you get sorted.
<!--QuoteBegin-trev150+--><div class='quotetop'>(trev150)</div><div class='quotemain'><!--QuoteEBegin-->The 8v dashes had a half moon rev counter, where as the 16v had the torque curve as the rev counter.<!--QuoteEnd--></div><!--QuoteEEnd-->
Thats a common mistake, the 16V GTE came with both types (curved and peak) of rev counter.
cobra148
<!--QuoteBegin-trev150+--><div class='quotetop'>(trev150)</div><div class='quotemain'><!--QuoteEBegin-->The GTE came with both types, not just the 16 valve, i beg to differ!<!--QuoteEnd--></div><!--QuoteEEnd-->
But above you said "The 8v dashes had a half moon rev counter, where as the 16v had the torque curve as the rev counter."
I've had the curved meter in a 16V, they were not used only in 8V's
cobra148
ok so who is gonna tell me how on gods green earth i fit on of these to my calibra? wiring diagram anywhere? a list of parts needed, dash, wiring and the transducer and it has to be a 16v digi dash.
how much do you think it would cost to get a gargae to fit one?
<!--QuoteBegin-trev150+--><div class='quotetop'>(trev150)</div><div class='quotemain'><!--QuoteEBegin-->yeah the 8v was still a GTE.
GTE 8v = half moon rev counter
GTE 16v = torque curve rev counter<!--QuoteEnd--></div><!--QuoteEEnd-->
I know, I've had an 8V and two 16V's, what I'm saying is the half moon rev counter was found in both the 8 and 16V models, not restricted to just the 8V.
cobra148
<!--QuoteBegin-cobra148+--><div class='quotetop'>(cobra148)</div><div class='quotemain'><!--QuoteEBegin-->I know, I've had an 8V and two 16V's, what I'm saying is the half moon rev counter was found in both the 8 and 16V models, not restricted to just the 8V.<!--QuoteEnd--></div><!--QuoteEEnd-->
how the heck do i tell which it is out of then? 16v or 8v?
