Inside door panels
Re: Inside door panels
RobbieV wrote:Yeah i would go with cloth trim door cards with the Vinyl tops as well
mine arent Vinyl and i wouldnt do the cloth thing i think it looks cheap and nasty
Unless you had them made then all interior door cards have vinyl tops.
RobbieV wrote:Unless you had them made then all interior door cards have vinyl tops.
that will be the reason there not vinyl Mr V
just found my passangers one has just went and done this
i got a mint 1 for my drivers door from a local scrappy for a fiver. if you look hard you will find
Are you gony leave it Fraz or try and get it fixed?
Fraz wrote:just found my passangers one has just went and done this
i think i have 1 if u want it fraz
its all the leds in the door card as well....so will need to swap that all over as well as the door card
will fix it at some point but I dont thing I will bother too much for now
time for a new car Fraz sounds like yours is past it
new car is a bit extrema Mr D ...maybe a new old one
I got a mint set of 4 couple of years ago for £40, and 2 of them have blistered!!....seems to affect the Cream interior alot more than the Black!
hence why i went to cream and cloth!
you it does seem to be the Cream that is the worse effected, but have seen black also doing it ...and mostly the passengers side as well for some reason
My passenger door card was blown when i bought the car, took me ages to find a set, swapped the lot over, and the passenger side went again....and the rear drivers side has gone too!!
Users browsing this forum: No registered users and 103 guests
