Turbo LE paint...
Turbo LE paint...
by complaints69 » Wed Apr 01, 2009 11:22 am
Hey guys & gals,
I need to know what the colour was called. I think it is Diamond Black, or is it Vauxhall Black???
I am going to sort some rust on my passenger door next week and the air-ass-holes in halfrauds do not have the paint codes on them, just paint names.
Calibra Turbo LE 28
Re: Turbo LE paint...
by rich_DTM » Wed Apr 01, 2009 2:00 pm
it was jet black wasnt it?
rich_DTM
by complaints69 » Wed Apr 01, 2009 5:00 pm
There is no colour under that name.
Calibra Turbo LE 28
by RobbieV » Wed Apr 01, 2009 5:04 pm
by Mark1 » Wed Apr 01, 2009 5:05 pm
It's not Diamond Black. Can you not get it from Vauxhall?
by STEVA » Wed Apr 01, 2009 5:16 pm
The colour iirc is op200 black ill have a look when i get home as im at work at the mo
by RobbieV » Wed Apr 01, 2009 5:36 pm
Check your paint code on the slam panel with the list i posted earlier.
If its not on the list then it could be Soild Black E200/80L.
by complaints69 » Wed Apr 01, 2009 6:50 pm
yes, my plate say's e200. The cans in halfrauds do not have paint codes on them, just names.
A while ago i purchased a stone chip repair kit from them and that was called vauxhall black and it looked ok on stone chips. I would like to be sure 100% that this is the right colour as i will be spraying the lower part of the passenger door and i want it to match!
Calibra Turbo LE 28
by complaints69 » Wed Apr 01, 2009 7:12 pm
Found it, it is Vauxhall Black.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... =WDVW&rd=1
Thanks guys. 8)
Calibra Turbo LE 28
by Robs Calibra » Tue Jun 16, 2009 8:33 pm
Hi
I met you around 2 years ago at Kent Modified. How is your Le. I still have mine and had it fully rebuilt by Courtenay. ALso had a 9litre intercooler fitted in the end. I am getting rust spots below my door, i must sort this out soon. I had it done, but they come back as water sits in there I guess. Is this your problem. Its not to bad but will sort it anyway soon. I remember the code being E200 as mine is an LE also so will be the same paint code.
by rich_DTM » Tue Jun 16, 2009 10:28 pm
i have the same problem could you post some update reports about the colour match please and photos if possible
rich_DTM
by bodgetastic » Tue Jun 16, 2009 10:36 pm
Interesting. Went into vauxhall before pvs to get some paint to 'touch up' the bonnet :lol:. Armed with my reg plate and vin number they still managed to order some rustic brown colour :evil: couldnt then find the right colour on the system and gave up.
My vin plate states colour code E200 but that meant nothing to them so if anyone could clear it up would be helpful for future reference :roll:
by Leigh » Wed Jun 17, 2009 11:21 am
Definately E200 for LE's and SE5's. It's just solid black paint, no 'flecks' or sparkles etc in it.
I'm sure I had a small touchup pot made up at my local Halfrauds years ago and the guy had no problems, maybe it's been removed from their database or something weird like that.
Diamond black will stick out like a sore thumb against solid black, I know from experience with a mates SE5 years ago trying to touch up some stonechips and scratches - it looks almost grey in comparison with the sparkles etc)
I've had a few cans of the genuine Vauxhall spray over the years from Autovaux (did delocked door handles until the bloomin Vauxhall system 90 packed up and I had to remove them..), seen them on ebay fairly reasonable price also.
Leigh
by the painter » Sat Aug 29, 2009 9:14 am
My ten pence! Go into Halfords and "hopefully" they will have a "custom paint mixing scheme". ( normally at the parts desk ).
They can make you up whats called a "professional aerosol" these have a better Nozzle on them and you get a better "fan" from the can, than the normal cans.
They can be a bit dearer but the paint match is normally excellent.
If youre still worried take the car too them and ask them to come and colour match it.
If you get really cross etc , pm me. ill help as much as poss.
the painter
by complaints69 » Sat Aug 29, 2009 9:04 pm
I got mine from my local car factors called Beaver Batteries. It was carplan paint i am sure, they cross referenced it against the e200 code and produced the can within 30 seconds. if you sprayed some in to the lid or something and then use a small brush or coctail stick to fill your chips or whatever.
Calibra Turbo LE 28
