After Burners available again!!!
by Teejay » Tue Jul 14, 2009 7:25 pm
I e-mailed quadconversions the other day about these and this is what they are saying:
Hi,
Yes, they are currently discontinued. We have started a list of people that would be interested in a kit and If we get enough names we will run another batch of the Calibra Afterburner.
We have to get them produced in batches of 10, so we would need atleast 6 names.
Woud you like me to add your name to the list? We may be sending out an email to see who is still interested very soon.
Regards Dave
www.quadconversions.com
www.kadude.com
www.kadude.co.uk
Re: After Burners available again!!!
by big_gordy » Tue Jul 14, 2009 10:19 pm
yip looks like it £295 inc 15%vat
by Phil69 » Wed Jul 15, 2009 12:07 am
If they are supplying in a bulk buy to that many people or more, I dont see why they shouldnt be able to give a discount. At the end of the day, them doing it in multiple buys means they are getting it cheaper anyway!
by vaggelis00 » Wed Jul 15, 2009 6:34 am
if the price is lower i would consider buing them :)
i just have to pay through paypal to somebody and he must take the responsibility to post them to Greece
vaggelis00
by big_gordy » Wed Jul 15, 2009 8:43 pm
Kenny wrote:Gordy - could give em a call and see if you can arrange a group buy for cheaper....?
will call em asap! :wink:
by Callyman » Thu Jul 16, 2009 6:33 pm
LED Rear lights
by big_gordy » Thu Jul 16, 2009 10:32 pm
i will need to call them at the week end as i have no time during the day so i will let you all know :mrgreen:
by vaggelis00 » Fri Jul 17, 2009 6:46 am
calibra's are ok with check control and led lights? we need anything extra so as not to light up the warning light?
vaggelis00
by drsswift » Wed Aug 12, 2009 6:53 am
add my name to the list
by MarkV6 » Wed Aug 12, 2009 8:26 am
vaggelis00 wrote:calibra's are ok with check control and led lights? we need anything extra so as not to light up the warning light?
As far as I know you had to fit an interface unit to not upset the check control, and it also incorporated the fog and reversing light into the main unit
http://homepage.ntlworld.com/gfx-tech/afterburnerinterface.htm
I used to own this Calibra...
I now own this one.
Xbox live gamertag IcedSage
by Fraz » Wed Aug 12, 2009 1:27 pm
you get the new style led rings now that have built in brake lights. and if they are still the same they leak as well
by Phil69 » Wed Aug 12, 2009 2:40 pm
You reverse the position of the central locking mechanism to face the latch assembly and shorten the rod that is originally fitted to the boot lock button in the original lights so that it is attached directly. You then run a pair of wires to where ever you want a button for the boot release on the inside of the car so when you press it, it releases the boot. No need for a lock anymore as you have to get into the car in the 1st place to press the button :)
by calibra_16v » Wed Aug 12, 2009 2:43 pm
ah right, should be quite easy to sort out then, might have to put my name down for a set :D
calibra_16v
by drsswift » Mon Sep 07, 2009 9:03 pm
woop woop. hehe. well happy. just spoke to quad conversions at the right time. they were having a clear out and found a set in the back. last ones they had. wahey
by vaggelis00 » Fri Jan 29, 2010 3:28 pm
finally today i managed to install the afterburners i had bought. i somewhat used the interface ubercustoms sell (i made my own). i have two problems.
my first is with the lamp check warning light. what kind of load resistors should i use to fool the lamp check?
my second problem is with tha abs lamp. after starting the engine it illuminates and i get TC 37 on tech1. what can i do about it?
vaggelis00
