any 1 ever used this stuff ?
Re: any 1 ever used this stuff ?
nope but read on detailing world a while back it`s good,may get some and try in on my cav turbo leather.
specks
yep - I use it in on my cali as I must have one of the few with an in-tact drivers bolster. Get the cleaner/conditioner stuff too. Take you're time and do lots of coats and build it up staedily, but it does a good job at stengthening weak leather and repairing scuffs.
1998 Calibra V6, 2001 Omega CDX Estate 2.6 V6, 1978 Triumph Spitfire 1500
the cleaner/conditioner he is meaning is the gliptone,now i have used that and is very good.
i had a gander on dw and only on very close inspection as in if you were really looking for it you could see a difference but only very,very slightly,as long as you do it to the letter in the instructions.
specks
yep - the gliptone cleaner/conditioner, thanks couldn't remember then name.
As to whether you can see it I'd say for small scratches, no. For bigger scuffs all you are doing is dying the scuff back to the original colour and applying a protective coat so it will never look the same as original but in my opinion it is a vast improvement.
Yep, definitely good stuff.
I go down the cowboy route now and use boot polish
Gav
