removing door and bumper protectors
as above do they pop off? or screwed?
are they easy to put back on?
cheers ryan
cheers ryan
ryan_warman
Re: removing door and bumper protectors
the door ones will slide off but will probably break the plastic retainers
the bumper ones will need the bumpes taken off as they're held on by metal retainers on the inside of the bumper
as phatom said! goto vx and get new replacement plstics not that dear but come in pask of 10! so you will have spares as u prob need 2 packs
And sliding the door ones off be careful you dont scratch the paint
Use a pair of side cutters and cut the metal retaing clips off the bunper ones. Its save alot of hassle or you could end up damaging the lugs or worse still end up snapping one
I managed to get the one off the front bumper with a small flathead screwdriver and didnt do any damage... wear some eye protection... they can ping off...
