removing the head lining
hello all i want to remove my head lining to try and fix my sun roof or find out what wrong is there any information pictures on how to do it?
is it a easy job to do?
cheers ryan
cheers ryan
ryan_warman
Re: removing the head lining
I took mine out today but as I'm scrapping the car I just pulled it all down. I have a complete working sunroof assembly if you need it?
Monkey
you will need to move all the rim off that holds it in also there is 3 metal pins at the boot end would take about an hour to do it !
Monkey wrote:I took mine out today but as I'm scrapping the car I just pulled it all down. I have a complete working sunroof assembly if you need it?
if u do what monkey says you will be looking for a ne head lining!!! lol
whats actually happeneing mate, ie when u pres the button for the sunroof can u hear the motor trying to move then stop....or just no noise atall..................i had noises from mine and turned out it was just the motor
daddyt
no i dont want to be getting a new head lining althrough i think i need one as the back isnt fixed to the roof
daddyt it just making like a clicking noise when i press the button so i was goingto take roof lining down then press it see what i can see
i'll give it go thursday once i've done the oil change want it working before i go away sunday
ryan_warman
