Bump strip clips
Bump strip clips
Having never removed the bump strips before I'm presuming the clips will break and will need new ones to re-fit strips after painting.
Are these still available anywhere?
Re: Bump strip clips
If you remove the front bumper the bump strips are held on with metal clips. They can be removed with a screwdriver and pliers and usually they can be re-used. They are near impossible to remove while the bumper is still on the car as you risk kinking the bump strip. I re-used the clips that were good when I removed and re-fitted mine and replaced the others with new ones from Vauxhall. I will post the part number when I find it they're only a few pence each.
James_Mould wrote:If you remove the front bumper the bump strips are held on with metal clips. They can be removed with a screwdriver and pliers and usually they can be re-used. They are near impossible to remove while the bumper is still on the car as you risk kinking the bump strip. I re-used the clips that were good when I removed and re-fitted mine and replaced the others with new ones from Vauxhall. I will post the part number when I find it they're only a few pence each.
Thanks James.
I wouldnt worry to much about the clips mate, i know of at least 2 calibra's running about who's bump strips dont have any clips on them
Or you can use small hose clamps, to keep them secured...
He may well have done, in May last year when this topic was last commented on!
Calibra SE4 3.2 V6 + F28
A Couple of German Cars!
