side trim removal
side trim removal
by Phill » Fri Nov 04, 2022 9:42 pm
Hi folks, can anyone tell me how to remove the side trim from the car
. I can move it about 1 to 2 inches left and right but I'm to feart to start using force on it :lol:
Could someone please put it on the Facebook page as I'm not on Facebook. Thanks.
Re: side trim removal
by Cliff » Sun Nov 06, 2022 8:18 pm
Hiya Phill
They just prise and slide off, the clips normally breaking in the process so you’ll need new clips.
You can use a plastic pry tool to help you, large flat trim remover.
Andrew
by Phill » Mon Nov 14, 2022 10:30 pm
Cliff wrote:Hiya Phill
Andrew
Thanks Andrew
can you still get the clips ? I would need enough to cover all the trim on both sides
by Cliff » Tue Nov 15, 2022 7:00 am
I’ve asked Richard - he’s going to try to come online tonight and see how he can help you. He’s a technique to remove them without breaking which would be even better.
by Phill » Wed Nov 16, 2022 12:12 am
Cliff wrote:I’ve asked Richard - he’s going to try to come online tonight and see how he can help you. He’s a technique to remove them without breaking which would be even better.
Thanks for asking Richard to give me some advice on this Andrew
by Cliff » Wed Nov 16, 2022 6:23 am
From Richard who had some trouble posting:
Morning bud give them a right good clean with warm water by poring it down the back to flush all the crap out. Then on the door at the front heat up the first inch or so with a heat gun or hairdryer to slightly soften the plastic then remove this one towards the rear or the car it should slide off off easy with the door open
For the rear quarter repeat this but slid it off into the door aperture
The front small wing one should also slide backwards when the doors closed this is the hardest one to remove.
by Phill » Wed Nov 16, 2022 7:21 pm
Cliff wrote:From Richard who had some trouble posting:
Thanks for posting that Andrew and could you please message Richard and thank him for the information I needed :D
by Cliff » Wed Nov 16, 2022 7:24 pm
Of course!
