Enhancements list for the new site
This thread is for me to collect action items for me to work on with the new look site based on feedback from others.
Outstanding:
Nothing....come on guys
Done:
- Replace feed active/new/unread text links with buttons
--- DONE: Added To Main Navigation Bar after "Club Membership"; removed unanswered and unread links - site now more aligned with pro silver theme (original site theme) - let me know if you find the navigation buttons more usable
- "Fix" active/new feeds which seem to completely clear for some users after they view once
--- DONE: I believe this is now working correctly - I have tested with two users, please let me have feedback if it's not working as expected and provide as much detail as possible
- Placeholder action - Dan's comment about fragmented reading - pending more info so I don't fix the wrong thing!
--- DONE: Dan reported back that this seems to be working OK now
- Table formatting for SE9 list
--- DONE: Formatting improvements applied to the stylesheet, increased the width of the topic areas so it should be wider now on your screen; added horizontal (bottom) scroll bars to allow scrolling on posts when they cannot fit on the screen
Will not be fixed/implemented:
- Add a test forum where members can practice with new added features without populating the main forums with noise
--- NOT DONE: In discussion admins were concerned it will become a bit of a dumping ground with all kinds of mess - for trials members can feel free to try as they post in the normal forums and if they make a mess can either delete/clean-up/edit their own posts or ask admin for support
Outstanding:
Done:
Re: Enhancements list for the new site
Hi Guys & Girls
Several improvements applied, some perhaps more visible than others. I will continue to maintain the above post but need your feedback to do so.
Going forward, after discussion with the other admins, I will only maintain the new style - that means that when I add new features/make changes, it will be to the new style only.
Old styles will NOT be removed so will still be there for you to use - but of course over time the functionality gap between old and new will grow.
So in summary, I'd rather get the new style working for all in a good way - and the only way for me to know it isn't is if you speak up
Thanks for your help!
Andrew
Andrew
