How to add pictures to your post
Want a Part or Item? Then put a post in this section.
by Cliff » Fri May 27, 2016 12:33 pm
The forum allows you to add pictures (maximum size 5MB) inline to your post and the following instruction explains how you can do this.
At the bottom of the post, you should be able to see the "Options" and "Upload attachment" tabs:
Click on the "Upload attachment" tab:
Click on "Choose File":
Select the picture you want to upload when prompted, then click on "Add the file":
Find the point in your text that you want to place the image inline and position your cursor there and then click "Place inline" for the image you want to insert:
Which should result in something that looks similar to this:
How to add pictures to your post (bulk method)
by Cliff » Fri May 27, 2016 5:21 pm
We have now added integration to PostImage.org which allows you to anonymously store your photos and auto-link them to your forum post. This makes it a little quicker if you have multiple photos to upload compared with the previous method.
To use the new integration, when posting you should click on "Add image(s) to post":
You DO NOT need to register. Simply select the files you want to upload by clicking on "Browse" and choosing them, set "Resize" to "800x600" and "Image Content" to "FAMILY Safe". Look at the following screenshot for an example:
Once done, click on "Upload It!" - your photos will be uploaded and links placed directly into the editor window like so:
