Sharpen up your steering - poly track rod bushes £24 inc p&p
by Chavtastic » Sat Dec 03, 2011 8:52 pm
Just thought some of you would appreciate this link.
Not seen many people running these but should be a good modification to reduce play in the steering!
£24.04 delivered
http://www.priracing.com/product.php/17 ... rod-bushes
Re: Sharpen up your steering - poly track rod bushes £24 inc
by Calibra_Mike » Sun Dec 04, 2011 1:11 pm
might treat myself in the new year...
by MadOnVaux! » Mon Jul 30, 2012 3:44 pm
Abit of a bump ;)
Ive been looking at these....anyone now got them, how easy are they to fit and is there a good improvement with them?
by Chavtastic » Mon Jul 30, 2012 3:48 pm
They are easy to fit, just press them in and out. Took me about 3 minutes each side.
And yes it was a brilliant different. It eliminated about 80% of the play in the steering.
by MadOnVaux! » Mon Jul 30, 2012 5:35 pm
Chavtastic wrote:They are easy to fit, just press them in and out. Took me about 3 minutes each side.
Did you fit them with the arms on the car or taken off?....they sound good though :)
by Chavtastic » Mon Jul 30, 2012 9:04 pm
Yeah I did, but I had the arms off anyway to be fair.
Not sure you'd manage it in-situ as you need a press ideally. Having said that, a G-clamp with a socket might do it (something like a 19mm looks about right size)
by MadOnVaux! » Thu Aug 16, 2012 3:50 pm
Just bought a set :)
They must have reduced them slightly as it cost me £23.38 delivered :)
by STEVA » Thu Aug 16, 2012 5:49 pm
Me too!!!! :D
by MadOnVaux! » Thu Aug 16, 2012 8:42 pm
Just wondering on fitment...haynes says to use a new locking plate on the inner tie rod bolts and new nyloc nuts on the track rod ends.....is is 100% necessary?
by craigyboy » Thu Aug 16, 2012 9:38 pm
MadOnVaux! wrote:Just wondering on fitment...haynes says to use a new locking plate on the inner tie rod bolts and new nyloc nuts on the track rod ends.....is is 100% necessary?
Mate you are always meant to replace nyloc nuts once you
take them off.
by MadOnVaux! » Fri Aug 17, 2012 4:33 pm
take them off.
Ok, but what about the locking plate?
by Fraz » Fri Aug 17, 2012 4:55 pm
usually the locking late will snap at one or more points, so if your that worried you should change it
by EddeyDancer » Sun Aug 19, 2012 5:58 pm
MadOnVaux! wrote: I've been looking at these... Anyone now got them, how easy are they to fit and is there a good improvement with them?
I've had them for a Year now...
Scroll down to the bottom of the page for some pics...
viewtopic.php?f=16&t=45499&start=60
by MadOnVaux! » Sun Aug 19, 2012 9:01 pm
The ones you have are for the anti-roll bar links Eddey...the ones we are on about are for the steering, they fit the inner tie tod, connected to the rack :)
by bodgetastic » Mon Aug 27, 2012 9:37 pm
Any excuse for a bit of powdercoating
