fuel pipe
Re: fuel pipe
I’ve never fit it so can’t help as such, what I do know is the pipe is 8mm - there’s oodles on eBay to choose from. Maybe someone who’s swapped them will come along though.
Re: fuel pipe
Thanks Cliff , I wasn't sure of the size I needed. I knew I needed about 8mtr's to replace both the lines.
Re: fuel pipe
As andy said its 8mm internal fuel injection hose and 8mm plastic if my mind serves me right its about 35 quid a roll from vauxhall and that should be enough to do flow return on around 3 cars
Re: fuel pipe
rich30mex wrote:As andy said its 8mm internal fuel injection hose and 8mm plastic if my mind serves me right its about 35 quid a roll from vauxhall and that should be enough to do flow return on around 3 cars
Thanks rich, I have ordered 10ft from eBay so hopefully that's enough to do the flow and return and 2mtrs of braided fuel pipe. Do you know if I need any 8mm pipe inserts when I jubilee clip the pipe to the Flexi pipe.
Users browsing this forum: No registered users and 61 guests
