Does DIII mix with DII pas oil?
I put some DIII oil in to top up the PAS and realised after adding a bit that i should be using DII. Will this casue much of a problem will they mix or do i need to drain and fill again?
gremlin
How's the best way to drain 4x4 pas then?
I took a look the other day - guessing it'd be best to pull the rubber pipe from the PAS pump off where it joins the metal pipework under the radiator??? just looks very fiddely aronud there with the a/c pipework etc... Any better suggestions?
Steve
Steve
