Windows stuck!
Windows stuck!
by noelboy » Thu Jun 16, 2005 8:44 am
For some strange reason my drivers side windows has stopped moving..
It was playing up at the start of the week, I could sit stationary for 20 mins and sometimes it would go up and sometimes it wouldn't. When it did move it sounded fine.Now it won't budge at all.
Where should I start to try and find the problem?
I've checked the fuse.......
noelboy
by SukySaggi » Thu Jun 16, 2005 11:04 am
Remove the door card a check to see if you're getting power to the motor. If yes then you're motor needs changing, if no check the window switch.
SukySaggi
by noelboy » Thu Jun 23, 2005 8:25 am
I've got the card off but how do I get to them motor?
Also I've got a Toad AI606 alarm, has anyone heard of these interfering with the windows?
noelboy
by noelboy » Thu Jun 23, 2005 9:13 am
Some more details:
The lights on both switches light up.
The fuses are all ok
The wires from the Toad box are all secure
Im baffled because when the window does move the motor sounds fine and is pretty fast????
noelboy
by SukySaggi » Thu Jun 23, 2005 10:49 am
If the motor does work intermittently then its probably a loose wire somewhere.
SukySaggi
by noelboy » Thu Jun 23, 2005 10:54 am
That's what im banking on but I don't know where to start in tracing the wires.
I want to test the voltage on the motor plug but with the door card off I cant see a way to get to it.....It's behind the skin.
I dont have to drill the rivets out just to get to the plug do I?
noelboy
by SukySaggi » Thu Jun 23, 2005 10:58 am
Thats the only way to remove the motor, but a bit drastic. Can you not see any wires going towards the motor? You could check the colour of the wires using a Haynes manual and then check the wires where they enter the door, near the door hinge/pin. Sorry I can't help more.
SukySaggi
by johnny_adidas » Thu Jun 23, 2005 11:31 am
mine does this also, funny thing is it always works on sunny days but im 2 afraid to open the window in case i cant get it back up. tink its about time though that i had a look and solved the problem
johnny_adidas
by King Calibra » Thu Jun 23, 2005 11:55 am
My driver's side window did that when I first got the car, and it turned out to be the motor. to the tune of about 250 euros!
The other day, when the temperature hit over 30, my passenger window started acting up! I hope I don't have to change that one now.
I wonder if the motor for both sides is the same? Because only my drivers window has the one-touch feature. I wonder if it's possible to use a driver's side motor on the other one to function the same way....
King Calibra
by johnny_adidas » Thu Jun 23, 2005 12:19 pm
luckily i picked up both motors and mechanisms for 45 euro on ebay
johnny_adidas
by noelboy » Thu Jun 23, 2005 1:36 pm
Anyone know the colours of the power cables to the door?
I havn't got the Haynes with me!
noelboy
by Monkey » Thu Jun 23, 2005 2:42 pm
The majority of the time it is the motor that is at fault. You should be able to get a decent replacement from a scrappers for around £20-30. You neede to drill the rivets out and rivet the new one in, the electrical plug on the back of the motor has a metal clip that needs to come off as well.
Monkey
by damon » Wed Jul 20, 2005 2:22 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->The majority of the time it is the motor that is at fault. You should be able to get a decent replacement from a scrappers for around £20-30.<!--QuoteEnd--></div><!--QuoteEEnd-->
Does it have to be from a calibra? 'Cos not much chance finding one of those where im from.
damon
