How to wire up a AFR gauge?
by Toddy » Tue Jun 28, 2005 11:09 pm
Anybody tell me in simple terms how to do this?
Just got a brand new one off Ebay for £14:D
Toddy
by trev150 » Tue Jun 28, 2005 11:38 pm
What connections are on the back, and what are they labelled up as?
Got any pics?
by haroldhettaturbo » Tue Jun 28, 2005 11:51 pm
Hi m8
Mines,
Red Live
Black Earth
Grey Lamba
HH
haroldhettaturbo
by Toddy » Wed Jun 29, 2005 12:07 am
HH mine has the same coloured wires, red and black no problem but where do I join into the lamba on a 93 Turbo?
Toddy
by ROG » Wed Jun 29, 2005 12:56 am
i ran the wire up through under the steering wheel and into the engine bay, just by the water bottle theres a plug for the lambda, i used to have the wire trapped in between the plug and socket , byt now ive got it joined properly, i think theres 3 wires 2 the same and one the other (black or white), it goes to the wire there is one of, i also ran the negitive to the engine block the same route to the earth for the fuel injectors on the fuel rail.
ROG
by Toddy » Wed Jun 29, 2005 8:47 am
Thanks Rog, don't suppose you've got any pics of which connecter/wire I'm ment to join it to.Will have a look around the water bottle (by this do you mean the washer jet resevoir or the expansion tank?) and see what I can find.
Toddy
by ROG » Wed Jun 29, 2005 9:13 am
havent got any pics , but it runs with the wires that run along the rear of the engine bay
The black plastic bit that covers the pollen filter and the windscreen wipers has a flap on the edge that folds up ( not under the cover ,just the edge of it in the engine bay,
It covers the wires that run along the rear of the engine bay, the plug is just after the brake fluid resivoir behind the corner of the engine on the drivers side, a wide black plug with 3 wires, about 1" wide
ROG
by Toddy » Wed Jun 29, 2005 10:03 am
Cheers Rog, will go hunt it down;)
Toddy
