cleaning V6 calipers?
by niggy0 » Thu Aug 04, 2005 2:57 pm
How easy a job is it to take the brake calipers off and clean them or replace the calipers any guides an how to do this?
Also anyone know where I can get a good but relatively cost effective (ok cheap) set from.
niggy0
by SukySaggi » Thu Aug 04, 2005 3:33 pm
I think its just a couple of alan bolts holding the calipers in place, so it shouldn't be too hard.
SukySaggi
by RobbieV » Thu Aug 04, 2005 3:51 pm
Yep 2 10mm allen bolts and slide off the disc [img]/smile.gif[/img]
by niggy0 » Thu Aug 04, 2005 4:00 pm
Cheers for that,
do you happen to know what the best method to clean them is,
Ie any special oil, detergent or carb cleaner type stuff?
niggy0
by SukySaggi » Fri Aug 05, 2005 1:47 pm
Use a drill with a wire brush attachment.
SukySaggi
by niggy0 » Fri Aug 05, 2005 2:11 pm
okay - will give that a go as soon as
that's if the little lady will let me loose with a power tool!!!!!!!
Cheers for all your help guys
niggy0
Users browsing this forum: Bing [Bot] and 8 guests
