Window Closure
Window Closure
by King Calibra » Thu Oct 27, 2005 6:41 pm
Do all calibras come with automatic window closure? I just got one of those total closure systems from Jimbohotpants and was wondering if it's even worth it.
Because I was informed after the purchase that it doesn't control the windows, just the sunroof!
I have no way of testin the key lock method, since my calibra's been de-locked.
If it's not standard on early calibras, is it possible to install it?
King Calibra
by King Calibra » Thu Oct 27, 2005 7:59 pm
please help, as I'm going to install the system tomorrow, and I want to know if Im just wasting my time.
King Calibra
by ealex » Thu Oct 27, 2005 8:11 pm
all the callys i ever seen had auto window closure. though it doesnt work perfectly
ealex
by King Calibra » Thu Oct 27, 2005 8:45 pm
<!--QuoteBegin-ealex+--><div class='quotetop'>(ealex)</div><div class='quotemain'><!--QuoteEBegin-->all the callys i ever seen had auto window closure. though it doesnt work perfectly<!--QuoteEnd--></div><!--QuoteEEnd-->
On models without remote keyless entry, where is the actuator for the window closure? My car has an alarm installed that controls the central locking, but not the windows. is there a way to change that?
King Calibra
by ealex » Thu Oct 27, 2005 9:16 pm
ah... i get where you're going. when u had the door lock, did u ever try to hold it turned to close the windows? if you dont have the windows linked to the locking then u should get the central locking unit off one that does
ealex
by a_c » Thu Oct 27, 2005 10:20 pm
Ive got a 'cobra' system on my car...And it only pulls the drivers window up...Doesnt do the passenger side...
its rather annoying actually, having to unlock the car, touch the little thingy on my keyring to the dash, and then turn the key...Especially when you turn the engine off, you have to re-do the whole thing!!! lock, unlock, wait for red light, touch the thingy with the other 'thing' then turn the key!!
a_c
by Mac » Thu Oct 27, 2005 10:45 pm
Take your motor to a n auto elecrics place that installes alarms and I am sure they will be able to link your window closer to your central locking fob operation, All the wires are in the passenger foot well, just a case of joining the correct ones.
Mac.
REME.
Mac
by MR_TOAD » Fri Oct 28, 2005 11:03 am
Brown Black wire add a negative feed to this wire it will close windows
can be found coming out of both front doors
It will not close sunroof as this is a seperate unit
Ian
MR_TOAD
by johnny_adidas » Fri Oct 28, 2005 12:04 pm
must try this out, cheers matey
johnny_adidas
by Fraz » Fri Oct 28, 2005 12:11 pm
Or down at the passangers kick plate the control module is there
you have seen <a href="http://www.akirwan.freeserve.co.uk/akhow2/RXDEADHT.RTF" target="_blank">this</a>
by jimbohotpants » Fri Oct 28, 2005 3:37 pm
<!--QuoteBegin-King Calibra+--><div class='quotetop'>(King Calibra)</div><div class='quotemain'><!--QuoteEBegin-->Because I was informed after the purchase that it doesn't control the windows, just the sunroof!<!--QuoteEnd--></div><!--QuoteEEnd-->
I thought I made it very clear that it only does the sunroof mate! If you're not happy, send it back and I'll give a full refund.
jimbohotpants
by jimbohotpants » Fri Oct 28, 2005 3:41 pm
Also, you need to have the microswitches fitted on both passenger and driver's locks! Dont ask me why these are needed, but the total closure doesnt work without them!
Mr Toad's right about the brown/black wire though, if these are in place.
jimbohotpants
by johnny_adidas » Fri Oct 28, 2005 3:48 pm
hey jimbo, meant to ask you before now, did u get them working on the redtop models? i seem to remember they were only definitely working on post 93 models.
johnny_adidas
by King Calibra » Fri Oct 28, 2005 9:39 pm
<!--QuoteBegin-jimbohotpants+--><div class='quotetop'>(jimbohotpants)</div><div class='quotemain'><!--QuoteEBegin-->I thought I made it very clear that it only does the sunroof mate! If you're not happy, send it back and I'll give a full refund.<!--QuoteEnd--></div><!--QuoteEEnd-->
Maybe just a misunderstanding. :oops:
Don't care tho. I WILL get the blasted thing to get my windows to close too [img]/laugh.gif[/img] I just wasn't sure if early reg calibras had the window closure at all.
Figured the best way to find out would be to pop a thread into the forum.
I'm not unhappy, just doing some research before I start chopping up wires. [img]/laugh.gif[/img]
King Calibra
by King Calibra » Fri Oct 28, 2005 9:42 pm
<!--QuoteBegin-MR_TOAD+--><div class='quotetop'>(MR_TOAD)</div><div class='quotemain'><!--QuoteEBegin-->Brown Black wire add a negative feed to this wire it will close windows
Ian<!--QuoteEnd--></div><!--QuoteEEnd-->
So, as a test, if I were to ground that wire out to the chassis, it would close the windows?
King Calibra
Users browsing this forum: Bing [Bot] and 33 guests
