window
window
My driver side electric window has stopped working. not worked for a few days now. i press to go down and no sound what so ever. the passenger side is fine.
About 3-4 days ago waiting outside the betterhalfs mothers and the window went down then up then down then up. then nothing at all again. its a pain because all the other electrics are working fine.
daz106
houston
I have window issues myself on a new car i bought. It can be quite hard to fault find.
If they're working intermittantly i would suggest you look at all the connections.
There is know wiring fault with some of the vaux window connectors, although the vauxhall info system says they do i don't get the impression cally ones are effected though.
However its worth pulling the handbrake area up, checking the switch unit is still properly plugged in there, the door to car flexi cabling isnt damaged, and that the connector is fairly clean and dry.. failing that its off with the door cards to check the motor end.. but that is unlikely to have come off, however there is a control unit on the window motor that might be up the creek, if you have a multimeter you can then test the power at the motor end to check the wiring is all ok.
