Warning left lights on buzzer
by alisdair » Mon Apr 19, 2004 6:11 pm
I know this may sound a bit daft, but I can find where the relay for the light on buzzer is.
Is it in engine or in the car?
Can someone please take a picture of it so I know where it is positioned.
Please
alisdair
by SteveU » Mon Apr 19, 2004 6:34 pm
It's in the fuse box to the lower right hand side of the steering wheel. Take the cover off and listen to it. You'll soon know which one it is.
SteveU
by alisdair » Mon Apr 19, 2004 6:37 pm
But I cant here anything
alisdair
by SteveU » Mon Apr 19, 2004 7:00 pm
Riggghhhtt, got ya. I can't even check at the mo cos I've left my Cally at work but if you look on the back of the fuse box cover then it should show it's location. The guide on CavWeb says it's on the left and the Vauxhall partnumber is 90 240 665 (this will be embossed into the top of the relay).
SteveU
by alisdair » Mon Apr 19, 2004 7:10 pm
You bloody beauty. I am going to check.
alisdair
by alisdair » Mon Apr 19, 2004 7:24 pm
90 464 777 is the number I think it might be. It seems to be top left. All the other relays are working for other things and the map on the cover shows this. The one I was looking at the cover has a W as the symbol.
If you have any idea's. Now being here in SA and the calibra being as rare as it is. Can I not just get one from an Astra or something or are they all universal???
alisdair
by SteveU » Mon Apr 19, 2004 10:17 pm
Best to get one off a Vectra as they have a nicer sound.
SteveU
by alisdair » Mon Apr 19, 2004 10:18 pm
SteveU, No Vectras here my friend. Any other ideas
alisdair
by SteveU » Mon Apr 19, 2004 10:34 pm
You're kiddin!?!?!? What do Opel have as a family saloon over there then?
SteveU
by alisdair » Mon Apr 19, 2004 10:37 pm
Astra or Zafira and Mavira or the Omega.
alisdair
by SteveU » Tue Apr 20, 2004 5:44 pm
Get one out of an Omega then, same one as a Vectra.
SteveU
by K5 » Tue Apr 20, 2004 6:30 pm
Aha! so this can be done! I always wanted to change the sound to the later version. It,s the little things that make all the difference. So any Later Vauxhall one should fit then?
K5
by Leigh » Wed Apr 21, 2004 12:46 am
Early = horrible buzzing / rasping noise
Later = two tone beeping ?
Leigh
by RobbieV » Wed Apr 21, 2004 6:41 am
I want to change mine so what am i looking for :?: Part number anyone :?:
by alisdair » Wed Apr 21, 2004 10:45 am
Ok took the car in today to Opel, here is the run down:
Relay is working fine (tested it in another car)
Wiring going to relay is fine (tested)
Behind ignition barrel and steering column ( wires all checked )
Any ideas please
alisdair
Users browsing this forum: No registered users and 237 guests
