blown bulb
blown bulb
The main headlight on the front passenger side has blown.Had a quick look at it,do you get to the bulb like you do on the rear lights?Or is it more complicated?Do I have to remove the head light unit?
metal-ste
it should be a h1 bulb. Take the blown 1 (u can tell if its blown cos the glass will look 'rainbow' coloured - that's the gas burnt) and go to halfords or sumat.....they'll find u the right 1.
When refitting DO NOT TOUCH THE GLASS PART OF THE BULB.
This will put grease on glass and blow the bulb b4 u even use it.
Hope that helps.
Hope that helps.
sev
