Urgent help needed
Urgent help needed
by daz106 » Tue Jan 03, 2006 1:52 pm
Out in the car the other night, when to start the engine and the ECU light didnt come on so wouldnt start. ignition off and on still no light, tryed this a few times, knocked the ecu location still nothing, turned the key a few times and finally light came on engine started and no problems. again when i went to mcdonalds, had to walk home with the food.
Went back to the car key in light came on engine started. few days go by, so think it was a one off. go to KFC (i eat out a lot) parked up went in, come back, no light no engine start up. after 5 mins of turning ignition on and off light comes on engine springs into life. then yesterday outside the local tesco go in get dog food come back to the car, again no light, try ignition on, off, on, off. so decide to walk home then the ligh comes on when the ignition is tryed on last time away we go. so havent used the car since and dont really want to incase im miles away and it wont start.
By engine management light a mean the orange light with the picture of the engine on the lightin bolt in it.
Its a 1992 16v redtop. its done about 120000. but the engine was new so has only done about 90000. its driving me nuts as its my only car.
daz106
by icewizard » Tue Jan 03, 2006 2:03 pm
Sounds like the injection relay is duff. It's the one fitted close to the ecu in the drivers footwell.
When they die they tend to stick and cause all the symptons you've described.
icewizard
by Mark1 » Tue Jan 03, 2006 2:26 pm
<!--QuoteBegin-icewizard+--><div class='quotetop'>(icewizard)</div><div class='quotemain'><!--QuoteEBegin-->Sounds like the injection relay is duff. It's the one fitted close to the ecu in the drivers footwell.
When they die they tend to stick and cause all the symptons you've described.<!--QuoteEnd--></div><!--QuoteEEnd-->
Sounds about right, also check all the plugs around the ECU when you change the relay.
Club Treasurer
Club Treasurer
by daz106 » Tue Jan 03, 2006 2:30 pm
What colour is the relay, i only ask because the fuel pump reply i have is blue and the spare i have is black???
daz106
by RobbieV » Tue Jan 03, 2006 2:55 pm
This is a fuel pump relay and they are the same for all calibras [img]/smile.gif[/img]
by Stupink » Tue Jan 03, 2006 3:32 pm
yeh, deffo fuel pump relay, I seem to recall mine is also blue, but I'm guessing its just a generic one someones put in.. perhaps even vauxhall, maybe they ran out or something lol. replacement part should be numbered as above
by daz106 » Tue Jan 03, 2006 4:18 pm
As said above its the fuel injection relay is it the same thing. The new fuel pump relay i have is the same as the black one above.
daz106
by daz106 » Thu Jan 05, 2006 2:15 pm
Sorry to bump topic but a need to know which relay to replace fuel pump or another one that controls fuel injection relay.
daz106
by Stupink » Thu Jan 05, 2006 7:16 pm
Fuel pump relay stops the ecu light coming on when its duff.
I think Iceman is talking about the same relay with a different name. fuel pump relay is the one by the ecu in the footwell
