remote locking
remote locking
by tonyse8 » Mon Jan 23, 2006 10:22 pm
has any1 ever fitted a remote central locking kit to there car? was it hard?
tonyse8
by RobbieV » Mon Jan 23, 2006 10:24 pm
Have a look in the Guides & Articles, there's a good "how to" in there [img]/smile.gif[/img]
by tonyse8 » Mon Jan 23, 2006 10:32 pm
yeah i saw that, just wondered if aany1 else has done it so i could ask afew questions??
tonyse8
by RobbieV » Mon Jan 23, 2006 10:37 pm
<!--QuoteBegin-tonyse8+--><div class='quotetop'>(tonyse8)</div><div class='quotemain'><!--QuoteEBegin-->yeah i saw that, just wondered if aany1 else has done it so i could ask afew questions??<!--QuoteEnd--></div><!--QuoteEEnd-->
There are a few of us that have used that guide to fit those remote locking kits [img]/smile.gif[/img]
by tonyse8 » Mon Jan 23, 2006 11:04 pm
ok then if i get any problem i am sure u guys wiil help.
tonyse8
by RobbieV » Mon Jan 23, 2006 11:06 pm
Are you fitting the Vauxhall remote central locking kit
by Leigh » Mon Jan 23, 2006 11:16 pm
As above, I fitted remote locking (Vaux kit - system 90 I think is the name), and the guide was VERY useful.
I was a bit wary about doing it as I don't like chopping wires etc, but it was fairly easy. My only 'mistake' was not getting a good earth point for the alarm, so at first it would lock and then take about 20 goes to unlock, and I could see the LED getting dimmer by the seconds as it drained..
I'd say try to solder the connections tho rather than using the scotchlocks, much tidier and securer (I could barely get the trim back on when I used all scotchlocks the first time)
Leigh
by tonyse8 » Mon Jan 23, 2006 11:21 pm
yes am gonna fit the systerm 90
tonyse8
by RobbieV » Mon Jan 23, 2006 11:22 pm
<!--QuoteBegin-tonyse8+--><div class='quotetop'>(tonyse8)</div><div class='quotemain'><!--QuoteEBegin-->yes am gonna fit the systerm 90<!--QuoteEnd--></div><!--QuoteEEnd-->
For help and advice just shout [img]/smile.gif[/img]
by TonyDTM » Mon Jan 23, 2006 11:37 pm
Fitted 2 remote kits on Vaux Cav and Cally. Both were alarm kits, both used 2 wires to the locking unit located in the drivers side footwell behind the trim at the bottem. When looking at the unit, the 2 wires at the front are the lock / unlock pulse connections. you might have to use a test bulb in there to work them out but once fitted to either a remote kit or an alarm they don't seem to give any problems. Only prob i have ever had with locks is the passanger door on my Cally had a "lazy" element and when locked on remote, popped open again. I changed the element and its been good as gold since.
TonyDTM
by mattm541 » Tue Jan 24, 2006 3:32 pm
Tony, What colour were these wires? Im trying to wire my alarm up, but dont know which wires to connect them too???
mattm541
by Rusty_CallyT » Tue Jan 24, 2006 3:40 pm
i fitted some cheap remote locking kit and found the wireing diagrams in the haynes to be excellent
Rusty_CallyT
by tonyse8 » Tue Jan 24, 2006 9:26 pm
iordered the kit today, £75 from vauxhall. the fun shall begin tomorrow!!
tonyse8
by TonyDTM » Tue Jan 24, 2006 9:33 pm
<!--QuoteBegin-mattm541+--><div class='quotetop'>(mattm541)</div><div class='quotemain'><!--QuoteEBegin-->Tony, What colour were these wires? Im trying to wire my alarm up, but dont know which wires to connect them too???<!--QuoteEnd--></div><!--QuoteEEnd-->
off the top of my head, i think one is black and the other is brown. easiest way to identify them is to get a piece of wire with an earth loop connector on it. screw it to the light pin switch on the drivers side A piller.
Take out the trim drivers side footwell. At the bottem, under the ECU is the central locking interface. undo the mounting bracket and drag it out. the end nearest to you are the 2 wires u need to check. take the wire and try it in each. it uses a negative loop so as soon as u hit the negative wire the door locks will pop.
The 2 wires for remote locking should be soldered or scotch-locked to these.
Hope that helps
TonyDTM
by mattm541 » Tue Jan 24, 2006 10:33 pm
cheers mate, ill ave a play around with it tommorrow. has anyone got any ideas the color of the wires to make the indicators flash when i set the alarm? i need 2 obv...
mattm541
