heating up
heating up
by johnny_adidas » Mon Jan 23, 2006 12:19 pm
ive been having a stuttering problem with the car whenever i was in traffic for a long time now. after fitting my air intake i thought it would solve the problem but it hasnt.
i remember someone suggesting it may be a temp sensor to someone with a similar problem. the temp shoots up to 95 when im in traffic but goes straight back down again when on the open road. ive basically found if i turn the heater on full blast while in traffic the water temp stays down and the car is fine. otherwise i get the stuttering until i get out of town and on the open road again.
is there some way i can turn the fan to turn on at all times without having to have the heater on or do i need a new thermostat as the fan is not coming on when needed or any other advice would be greatly appreciated?
johnny_adidas
by johnny_adidas » Mon Jan 23, 2006 12:27 pm
by the way its a 93 redtop
johnny_adidas
by callyben » Wed Jan 25, 2006 1:24 am
im sure there is a how to thread on mig (i know but it can be usefull sometimes)
but it must be caused by something else not the temp.
callyben
by callyben » Wed Jan 25, 2006 1:25 am
<a href="http://www.migweb.co.uk/forums/showthread.php?t=207354" target="_blank">http://www.migweb.co.uk/forums/showthread.php?t=207354</a>
linky
callyben
by johnny_adidas » Wed Jan 25, 2006 9:59 am
cheers mate, but just getting that i dont have sufficient privileges. can u post the thread name and ill search for that if u get a min?
johnny_adidas
by johnny_adidas » Wed Jan 25, 2006 11:19 am
after a bit of searching, looks like a low temp fan switch the way to go but is it much bother to fit?
johnny_adidas
by johnny_adidas » Thu Jan 26, 2006 10:56 am
just standard air box, panel air filter and a big hose running from just under the front bumper to the air box.
checked the temps again, had it wrong, its actually down at 82 or so normally and then goes up to 90 in traffic.
any suggestions why it doesnt happen while i have the fan on? possibly worth draining and replacing the coolant?
johnny_adidas
by TommyC » Thu Jan 26, 2006 7:23 pm
Some sort of thermostst fault??
Could try fitting a cool running thermostat?????
TommyC
by TonyDTM » Thu Jan 26, 2006 7:42 pm
If it was mine, i would fit a new thermostate and seal and a new temp sender switch. Having the heating on full blast would be making the water circulate more and has a chance to cool. If the heater is off and the water stationary so to speak, its gonna bubble up alot quicker. Could be a prob with the water pump but i would go for the cheap fix first before splashing out. Flush thru and new coolent in this weather seems wise.
TonyDTM
