Fuel computer
Fuel computer
Finally managed to fit it. The yellow plug was a ba**ard to reach as it was clipped up behind the radio cage. But now its working i can safely say that at 10 miles an hour round the block, i can do 127 miles on whats left in me tank !
TonyDTM
Ooh I remember playing hunt the yellow plug [img]/smile.gif[/img]
Mine was cable tied to one of the thicker looms, behind the small plastic siding in the radio cage area , could see it fairly easily (well at least one edge of it) so I knew it was there, but cutting that cable tie was a nightmare!
Leigh
i got it sorted Fraz. That was wot it first said when i plugged it in (hot-plugged it). After it was all in and the centre console all in one piece again, i dis-connected the battery. Its working as it should now.
It was from a Cav SRi eco. same engine, same wiring. I dont think it will give any probs.
TonyDTM
<!--QuoteBegin-Leigh+--><div class='quotetop'>(Leigh)</div><div class='quotemain'><!--QuoteEBegin-->Ooh I remember playing hunt the yellow plug [img]/smile.gif[/img]
Mine was cable tied to one of the thicker looms, behind the small plastic siding in the radio cage area , could see it fairly easily (well at least one edge of it) so I knew it was there, but cutting that cable tie was a nightmare!<!--QuoteEnd--></div><!--QuoteEEnd-->
yeah, u know it !!
yeah, u know it !!
TonyDTM
<!--QuoteBegin-pr0xZen+--><div class='quotetop'>(pr0xZen)</div><div class='quotemain'><!--QuoteEBegin-->Anyone reprogramming these without ripping you off? I need one reprogrammed for c20ne. It also has to be shipped from/to Norway so the shipping costs alone are sick. GM here charges around £80 for a new chip.<!--QuoteEnd--></div><!--QuoteEEnd-->
Hi, Ian might be able to help you, more info here on his website [img]/smile.gif[/img]
<a href="http://www.abs-zero.com/" target="_blank">http://www.abs-zero.com/</a>
