remote locking
Tony, I assume you've already searched for stuff , but I just looked back and found my original (longggggg...) posts when I was fitting my kit and having problems.
Theres a bit in there about some info I found relating to the wiring looms, unlocking probs etc..
Post is <a href="http://www.clubcalibra.net/forum/showthread.php?t=2297&highlight=remote+locking" target="_blank">Here</a>
(I did go back and solder the connections by the way!)
Leigh
yeah, just read it. I guess it depends on which kit you go for as to which wires, what colours etc etc. As i have said (soooo many times) test lamp, solder iron and a good earth is all i needed to do the job and it took little over a couple of hours from start to finish. The instructions i had with mine weren't worth a toss, but the diagram and wire colours were a bit of a help. Bout 8 wires and a birds nest of cabling under the dash....
AND A GOOD EARTH !
AND A GOOD EARTH !
TonyDTM
thanks alot for that leigh!!! i know the stress and sleepless nites that you went through as i am experiancing exactly the same problem now, its lockin but not unlockin.i am pretty sure its not a earth problem on mine as it is on the glovebox earth. have not tried disconnecting the brown/red wire, if this works u shall have a BIG reward!!!
tonyse8
right guys after yet ANOTHER day of looking at the wiring and re checkin the wires i think i may have finally come to the problem!!!!! i noticed that when i picked up the main control box it locked the doors!!!?? everytime i touch it it locks them, gonna go vauxhalls monday and show them the problem and demand a replacement!
tonyse8
replaced old box with new 1 and it no longer locks when u touch it:) but supprise, supprise it still does not unlock:mad: i really cant figure this out now, i have phoned the helpline and they cant understand it either? there is 2 options now, either go vauxhall and get a replacement barrel£30 or pay some one to look at it? anyone got any ideas?????
tonyse8
Users browsing this forum: Bing [Bot] and 35 guests
